Thread: Cover concrete decking with Tile.
    Dec 2007
    NW Georgia
    56
    Not sure if this is the right place but I have a few questions about using tile to cover over a concrete deck?
    1. What type of tile is best to use?
    2. Is the tile slippery when wet?
    3. How do you cover the coping edge of the pool? My pool has the cantilever concrete edge.
    41K L shape Vinyl IG, 2.0hp Jandy stealth pump, 300lb sand filter, Autopilot Dig-220 SC-60 cell, Dolphin Oasis Z5.
    30,432
    Re: Cover concrete decking with Tile.
    Quote Originally Posted by Simearl
    1. What type of tile is best to use? Porcelain is the least porous but I have seen other types, including saltillo, that work fine in your mild climate
    2. Is the tile slippery when wet? It certainly can be. YOu must choose one that has a rough or gritty surface
    3. How do you cover the coping edge of the pool? My pool has the cantilever concrete edge. Wrap the tile around and underneath
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Well, NW Georgia can have some snowy, icy times, so you should be careful. Any tile you consider should be frostproof...your everyday interior bathroom or kitchen tile will not hold up. OTOH, you might prefer a travertine, which also has bullnose coping to match.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Dec 2007
    NW Georgia
    56
    Thanks for the reply. I'm not sure what I really need to do. I got ripped on my concrete decking, the top layer of the decking is flaking off due to the fact that it got down below freezing the night after it was done. I am thinking about doing Kool deck but not sure if this is the right way to go either.
