Thread: Eidolon: New from Raleigh, NC
    May 2016
    Raleigh
    5
    Glad to be signing up for this forum. I've looked around and there's a LOT of good knowledge, here.
    I purchased my home and with it my pool a year ago as of just yesterday. Last year the equipment worked well enough and with a basic chlorine test kit (probably just TC), I was able to keep the pool clear. This summer, as I've opened it, the equipment has proved problematic and the water is still a bit murky. So I'm here to take charge of my pool and get it up to my standards, overall.
    I don't currently have a test kit that will allow me to provide pool chemical levels in keeping with this forum's standards. So that'll be one of my first purchases. Next is upgrading some of the pool equipment. For that, I'll post a separate thread.
    Glad to be here and I look forward to getting my pool running better than ever!
    18k gal, IG Gunnite, SuperII 1HP pump, Tagelus TA-60 31sqft sand filter, X10 home automation control. Well water for refill (3 GPG hardness).
    Pool equivalent dimensions: 13.5' x 33', deep end is 76", shallow is 54".
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Eidolon: New from Raleigh, NC
    Welcome to TFP!
    I recommend the TF100 from TFTestkits.net, I've been buying mine there for years.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,253
    Welcome! Good to have you join the forum
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
