Thread: Reagent R-0013. Owner of TF-100 & Taylor K-2006c
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Good evening everyone!
    I already asked a question about the compatibility of the reagents for both kits. The question was answer. Than you.
    Now, I have another question. Can I use the reagent R-0013 (CYA) that came with the TF-100 with the small plastic bottle that came with the Taylor 2006c?
    The bottle from the Taylor 2006c is a little smaller. Will I save some reagent?
    Or it will not give me accurate test results?
    Thank you all!
    15K gallons, Plaster, Taylor K-2006C & TF-100, DE, non SWG, Hayward TriStar VS variable pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Reagent R-0013. Owner of TF-100 & Taylor K-2006c
    As long as you have enough to fill the view tube high enough for the dot to disappear, you've mixed enough. Might be prudent to mix enough to fill the view tube to the top, though, just in case.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Thank you. I understand.
