Results 1 to 16 of 16
Thread: How do I get my water clear
    May 2014
    Tea sd
    13
    Hi there.
    Pool is 24' above ground pool. Have problem getting water clear. It's a real sharp blue. I can only see maybe a foot under surface.
    Here's the numbers
    Fc 1.5
    Cc 1
    To 2.5
    Ta 80
    Cya 20
    Thanks!
    24' Round doughboy above ground pool
    Vinyl liner
    Sand filter
    Installed 2012
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: How do I get my water clear
    I don't see a pH number?
    How are you testing...which kit?
    Have you delved in to the pool school articles at the top? This is a good start- ABCs of Pool Water Chemistry
    May 2014
    Tea sd
    13
    Haven't been able to get back on here till now.
    Thanks for response.
    Test kits are tf100.
    Today's tests are:
    FC .5
    CC .5
    TA 80
    CYA 20
    PH 7.5
    I have those articles. I was hoping someone would see something I don't, saving me some money.
    Thanks again!
    Vinyl liner
    Sand filter
    Installed 2012
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Welcome to TFP
    Yes we see something. Your choline is too low. To clear your water you need to SLAM your pool.
    Shock
    Level
    And
    Maintain
    You also probably want CYA a bit higher--30.
    Read this article. Pool School - SLAM - Shock Level And Maintain
    And post any questions you have.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,042
    You've got the tools and the information. SLAM
    Add some CYA to get to 30. If you don't have a partial canister laying around, do you have any dichlor "shock" or trichlor pucks? A little over a pound of plain CYA or two pounds of dichlor or 4 trichlor pucks will add the CYA you need. The dichlor and trichlor will likely also push your pH down where you want it. The dichlor will dissolve fastest.
    Then hit it with bleach, targeting 12 FC. And keep testing every couple hours and keep bringing it back to 12 FC. Brush till your arms ache. And if you can beg a coffee can's worth of DE or cellulose from a neighbor, that will speed up the filtration of all the algae you've killed.
    May 2014
    Tea sd
    13
    Latest reading
    FC 8
    CC 2
    PH 7.2
    TA 90
    My slam said FC 14 so I just put 2 jugs of bleach in along with 3 pucks to raise CYA
    I'll check next hour and see where I'm at.
    Any advice other than to keep slamming?
    Thanks!
    Vinyl liner
    Sand filter
    Installed 2012
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,570
    Keep the pump running 24/7, brush the pool at least once a day to help get stuff up and out.
    OH and keep SLAMming (sorry had to LOL)
    Kim
    May 2014
    Tea sd
    13
    Filter is always on ��
    Thanks!
    Vinyl liner
    Sand filter
    Installed 2012
    May 2014
    Tea sd
    13
    Thanks!
    Well new readings
    FC 17.5
    CC 0 to .5
    PH 7.2
    TA 110
    I can't test cya now correct?
    Vinyl liner
    Sand filter
    Installed 2012
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    It is the PH test that becomes invalid with elevated chlorine not CYA but.......CYA is not something that gets consumed by algae or sunlight as chlorine is. So....if you haven't added any stabilizer or stabilized chlorine product (like granulated "shock") then your CYA would be no different than your original test
    What else can you do? Brush a lot. Algae doesn't like that.h
    May 2014
    Tea sd
    13
    Thanks!
    Vinyl liner
    Sand filter
    Installed 2012
    30,426
    There is an absolute TON of wisdom in those FEW words.....nice post!
    May 2014
    Tea sd
    13
    Still at it.
    FC 13
    Cc bounces from .5 to 1
    Ph has been 7.2
    Cya 30
    Doing a bunch of brushing and vacuume
    Sometimes when I back flush the water barely comes out. Maybe half as much as should.
    So I set it to filter then back to backwash and filter. Works better then. What gives?
    Also when I turn multi port valve it seeks. Going bad or already is?
    Thanks folks!
    Vinyl liner
    Sand filter
    Installed 2012
    Jul 2012
    Tallahassee, FL
    30,570
    Time to take your pump apart and look inside at the sand and laterals and look at the gasket under your valve. it might be time to replace the gasket.
    Kim (I think mine is about to need replacing also)
    May 2014
    Tea sd
    13
    I'm thinking about going to a de filter
    Vinyl liner
    Sand filter
    Installed 2012
    Jul 2012
    Tallahassee, FL
    30,570
    That is up to you. Ranking filters it does like this:
    For clearest water:
    DE
    Cartridge
    sand
    For easy of care:
    Sand
    cartridge
    DE
    Did you know you can add DE to your sand filter to help polish the water?
    Pool School - Add DE to a Sand Filter
    It is up to you. I would do a search on cleaning a DE filter to make sure it is something you want to do.
    Kim
