Thread: Cannot get pool clear
    May 2016
    Muscatine Iowa
    3
    Hi all,
    First time poster and new member. Anyway we an 15x30 IG ~ 21k gallons. When we opened the pool almost 5 weeks ago the water was clear and we had dirt etc on the bottom. When we went to start the pump up, the motor was seized up. With it already warm enough out I knew algae was going to be a problem if I didn't get it running. Having a home warranty the pump was covered. The problem was it was about a week later and the warranty company was dragging their feet. So I went ahead and worked on the pump motor and got it running. Sounded like a 747 taking off but I had to get water circulating. By this time the water was very dark green. I ran the pump for short periods of time still waiting on the new motor. After not being able to wait any longer, I just ordered a new motor, seal kit and got it going. I then SLAM'd the pool. Eventually got the perfectly balanced. Currently have Hayward Pro Series High Rate Sand filter 300#. 1HP Super Pump. I was running at 15 on FC and TC. Now I am at:
    4 FC
    4 TC
    PH 7.2
    CYA 20
    CH 107
    TA 123
    (LaMotte Colorq Pro 7)
    The problem for over two weeks the pool has been cloudy with a bluish green tint and I cannot get it to clear not matter the numbers of the water. I bought floc but I want to use it as a last resort. I am at a loss. I know sand filters are slow but 2 weeks with good numbers? OCLT is holding for the last week as well. Please help!
    Thanks!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: Cannot get pool clear
    Welcome. There is an article in Pool School about adding some DE to your sand filter to hopefully help clear it. Keep your FC a couple points higher for a few days.
    May 2016
    Muscatine Iowa
    3
    Quote Originally Posted by woodyp View Post
    I will try that ASAP. I have been backwashing regularly. I opened up the sand filter and checked the sand level, for dirtiness, clumping and channeling. All was good.
    Thanks!
    May 2016
    Muscatine Iowa
    3
    Wanted to update everyone. The pool is crystal clear now. Had to keep shocking it into submission and was adding DE to the sand filter and that did the trick. Couldn't have done it without the plethora of knowledge on this site!
    Jun 2014
    15,271
