Thread: Covering your pool
    DobermanOwner's Avatar
    Mar 2016
    Topeka Kansas
    36
    Covering your pool
    Is it necessary to put the cover on your pool every night or can you leave it off all summer?
    16' x 48" (5,145 gallons) Coleman Power Steel round frame above ground pool
    1500-2500 gallon Coleman model# 90401E cartridge filter (stock)
    Intex Deluxe Wall Mounted Skimmer
    TF-100 test kit
    Set up and Filled May 2018 (3rd summer with it)
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Re: Covering your pool
    We cover ours every night until it gets to warm, then we leave it off for a night. Just a balance of how warm you want to keep the water. We like it around 84-88. Once it gets over 88, we leave it off for a night to bring the temp back down. It also keeps the bugs out by putting the cover on.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Mar 2016
    Topeka Kansas
    36
    We aren't picky about temp, we have swam twice so far, both at 74 degrees. I just wasn't sure if it effected the chemistry at all.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I put mine on at night, as it goes into the 50's here most nights, and it helps keep too much heat from escaping. I usually take it back off in the day, as it seems to actually heat up more if it's sunny without the cover. We also have periods of high pollen, the cover helps some.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Keeping heat in the pool overnight is the only reason to keep it covered. Leaving it uncovered is fine.
    JoyfulNoise's Avatar
    May 2015
    13,262
    Quote Originally Posted by DobermanOwner View Post
    Cover a pool reduces the outgassing of CO2 which is the primary driver of pH rise. A covered pool will experience lower acid demand of your pool's pH tends to rise.
    An opaque cover during the day, or one that absorbs UV, will also cut down on FC loss by reducing the amount of active chlorine lost to photolysis.
    Finally, a cover should be removed at least a couple of hours per week to allow chloramines to outgas.
    Matt
