Thread: One week after starting TFPC Results
    May 2016
    Brandon, MS
    34
    It's been one week since a light mustard algae problem finally made me embrace the TFPC method.
    Before:
    Last season my new pool was completed on July 2. The pool store instructed me to add 20 lbs of CYA, 2 lbs of shock once a week, algaecide weekly, and 25 oz of clarifier per week. This maintained my FC at 1-1.5, which is exactly where the pool store told me to keep it.
    By September 30, I had battled a huge green algae problem, and was battling mustard algae at season end. The pool store solution was to try to sell me "activator" for $300 which will "guarantee" that I never have algae again. Thankfully, I declined. The next solution was to "shock" the pool with 10 lbs of chlorine and floc the pool (another $75 in chemicals).
    I got the pool clear and maintained it with Cal Hypo throughout the winter, at least good enough to keep it clear. We have a fairly warm season all year, so we don't cover the pool...we still like to sit by it during winter.
    I opened the pool in March of this year for swimming, and added about a 1 lb of Cal Hypo every two days, and still couldn't get chlorine above a 1. Three mustard algae blooms by May 15th, each time using about $35 of sodium bromide per the pool store.
    After TFPC:
    I performed the SLAM procedure as directed, within four days the water was perfectly clear. FC loss about 2-2.5 per day now. About 70 oz of 10% bleach per day at a total cost of about $1.50 per day. If things keep going like this the rest of the season, I will spend less on all my maintenance costs than I did last year in two months.
    The TFPC method is awesome!
    Greg - Mississippi
    18' x 36'* 23,000 gallons * Vinyl * Manual Chlorination * Pentair Sand Filter * Pentair Variable Speed Pump * Polaris 360 * TF-100 Test Kit
    Jun 2014
    15,157
    Re: One week after starting TFPC Results
    Wonderful!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Kind of amazing how easy it is, huh?
    With all the money you'll save.... CLICK HERE to Become a TroubleFreePool.com Supporter!! Somebody had to ask.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Nice job clearing up your pool!
