Thread: Inlet/Outlet for Coleman Above ground pump
    May 2015
    Atlanta, GA
    6
    Angry Inlet/Outlet for Coleman Above ground pump
    The pool manual is mostly useless. I have 2 sets of inlets/outlets, not sure which is which. I've searched online, only find things about set up for the outside, not a picture of what it looks like on the inside. I think I have both set up with the outlet filter? Maybe it doesnt matter. Either way, feeling confused and frustrated!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Inlet/Outlet for Coleman Above ground pump
    There should be 2 the same height, those are the suction side and the other higher hole is the return from the pump and filter..
    here is a post that shows how it is hooked up, the 2 connections on the right are the suction side and the 1 connection on the left is the return
    Convert Intex 12 FT x 30 IN Metal Frame 1-1/4 IN Plumbing to 1-1/2 IN Plumbing
    May 2015
    Atlanta, GA
    6
    I have the outside hooked up fine, its the inlet/outlet on the INSIDE. I have 2 sets of these....
    Amazon.com : Intex 1.25 in. Small Pool Strainer Connector INLET Garden
    As of this very minute my father in law put the bottom/right on both A and B on the inside.
