Thread: New intex 18' x 48" above ground pool... what to install on
    May 2016
    Mountain view mo
    1
    Hi all. I'm getting ready to set up a new pool, intex 18'x48" round. My brother dragged a spot clear with his tractor but it's still not level. My question is, should I put down something like crushed gravel or sand (or both) and level it before setting up the pool? Thanks.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New intex 18' x 48" above ground pool... what to install on
    Welcome to TFP
    Most dig down but you can use rock and sand to build up, I used crushed rock and sand, you need to be within 1 inch of level.. here is a pic of what I did
    This was after the sand was put on top of the rock
    May 2016
    New Milton, Hampshire, UK
    28
    Is that Styrofoam?
    Jul 2013
    Fletcher, OK
    3,353
    Casey's Avatar
    SW PA
    10,457
    Either dig down to level or bring in the crush.
