Results 1 to 7 of 7
Thread: Pool Pad Location
    Jun 2015
    Baldwin, Maryland
    146
    Pool Pad Location
    Sorry guys, I searched, but couldn't find anything. I have 16'x32' APG. I just added a second skimmer and am thinking of moving the equipment pad to the side of the house.
    Pump is 1.5HP Pentair Superflo VS 34001. At the new pad the pump inlet will be 3.5' above water line 45' away (figure 60' through the pipe). I'm running all 2". I know the pump can handle that, but what is everyone's take on this? I can gladly upload some pictures to give you a better idea. I don't want to do something without asking for advise first. I was even thinking of just running 2" flex everywhere underground so NO fittings are underground.
    Thoughts?
    My second option would be to put the pad in the middle of the yard ~ would be ugly and a little pain to access the heater for the spa in winter... but would be 10' of run before getting to the pool
    Thanks guys!
    13.6K AG (I think?) 32'x16' Oval, Pentair SM8150 cartridge, Pentair SR400LP, Hayward Power Flo Matrix 1.5HP pump, Installed spring 2014 (hand me down, 4 years old when acquired), TF-100 Pool water test kit w/speed stir, Intex SWG (going since 2014), Well Water used for fill/top off
    38,275
    Re: Pool Pad Location
    I prefer hard PVC over flex, but we get no hard freezes. Not sure what the norm is in your area.
    The pump will work fine as you describe. Priming might take a little longer. One option to help would be adding check valve on the suction lines. Use good flapper type ones, like Jandy.
    Jun 2015
    Baldwin, Maryland
    146
    It does freeze here in Maryland. Flex is just what I've seen pool companies use, but I have easy access to hard pipe. I can hard pipe it, would be cheaper, but can I ask why? Just out of curiosity?
    Thanks, hadn't thought of that but will do!
    30,419
    Generally, we think of hard pipe as a more permanent connection and it is certainly a bit less prone to leak. Flex leaks are reported hefre on the forum more so than hard piping.
    38,275
    I agree with what Dave said, but there are many posts that refer to using flex PVC due to dealing with the freeze cycles, I have no experience with that.
    Jun 2015
    Baldwin, Maryland
    146
    Thanks guys, no issue with freezing..I'll blow the lines out and winterize. Hard pipe it is.
    38,275
    I think the concern was the ground shifting from the freeze thaw cycles not necessarily the water in the pipes.
