Results 1 to 10 of 10
Thread: Stain Around The Pool?
    May 2016
    Toledo, OH
    81
    Hello there. I have a light brown stains that is surrounding my pool and present on the floor in the shallow end. I have tried brushing but it just won't come off. I have added some pictures in. Also I am still waiting for my K-2006 test kit to arrive. Should be here on Thursday or Friday. Pool store said I just needed to add Calcium. I was at 190.
    Thanks!
    15,500 Gallon - In-Ground - Gunite Pool - Kidney Shape / Hayward S220T Sand Filter / 3/4 HP Hayward Pump / K-2006 Test Kit / Chlorine 3" Pucks
    Apr 2013
    Sacramento, CA
    2,769
    Re: Stain Around The Pool?
    Do you have a heater?
    Some ideas:
    1. Rub some crushed Vitamin C in a sock over the stain. If it does something after 5 minutes, its a metal, most likely Iron. If that doesn't work. Go down. If it does work search Ascorbic acid treatment on here.
    2. Hold a trichlor puck against it for five minutes. If it works then its organic. That can be solved with proper chemistry. Post your numbers. We can help.
    3. Is it rough? it might be calcium build up. Again chemistry solution.
    4. None of the above working. Buy Jack's Magic stain ID kit.
    May 2016
    Toledo, OH
    81
    Quote Originally Posted by gwegan View Post
    Some ideas:
    1. Rub some crushed aspirin in a sock over the stain. If it does something after 5 minutes, its a metal, most likely Iron. If that doesn't work. Go down. If it does work search acetylsalicylic acid treatment on here.
    Thanks for the tips. No heater I took it out last year. It was not operating but water was passing through it. I will start with the aspirin. Thanks
    May 2016
    Toledo, OH
    81
    I went ahead and bought the Magic Stain Kit. I believe I have a buildup of copper. Solution #2 bag seemed to lift the strain. Does the use of algaecide result in copper stains? I also used my new k-2006 kit tonight and have the following results.
    FC: 1.0
    CC: 11.8
    pH: 7.1
    TA: 60
    CH: 220
    CYA: was coming up less than 30
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Lets talk about your FC and CC..........Please tell me you got those mixed up..........
    Kim
    May 2016
    Toledo, OH
    81
    Quote Originally Posted by kimkats View Post
    Kim
    Possibly. I didn't think that was right.
    May 2016
    Toledo, OH
    81
    Are my results even realistic?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yes, the three most common sources of copper stains are
    Copper based algaecides
    Copper based mineral sanitizer systems
    Copper heat exchangers eroded by low PH water, below 7.2, over time
    Raise your PH up to 7.5 or so with borax or aeration
    Retest the FC/CC
    How have you been chlorinating the pool? No pucks, tabs or dichlor shock? Then your CYA could be low.
    More on stains here, Pool School - Metals in the Water and Metal Stains
    You can clear metal stains following this, Ascorbic Treatment to rid Pool of metal stains
    Add your pool info to your signature so that we can better help you, more here, Pool School - Read This Before You Post
    May 2016
    Toledo, OH
    81
    Quote Originally Posted by pooldv View Post
    How have you been chlorinating the pool? No pucks, tabs or didhlor shock? Then your CYA could be low.
    I used some Power Plus shock a week or so ago when I took the cover off. About 10lbs. Now I have the chlorinator set on low with the pucks loaded inside. Thanks for the tip on the signature. I have added that in.
    May 2016
    Toledo, OH
    81
    I tested the water again tonight with and got the following:
    FC 4.0
    CC 6.5
    pH 7.9
    TA 60
    CH 240
    CYA less than 30
    I took a couple pics while in the water of the stain. I tried both the vitamin c and puck tests to remove the stain and nothing happened.
    Last edited by MAndrews1; 06-03-2016 at 09:25 PM. Reason: Added metal test results
