Results 1 to 10 of 10
Thread: We're Back!
    Jul 2015
    Central NJ
    55
    We're Back!
    Pool is freshly (delayed) opened and first readings are in !
    TA= 50
    CYA= 60
    CH= 125
    ph= 6.8
    FC= ~0
    First year we're opening the pool. Poolman said all looks good... but now it's on me to get it to TFP standards.
    IIRC, these were my targets last year:
    ph= 7.5
    TA= 50
    FC= 8
    CYA= 75
    Currently looking into SLAMming it down and then getting in there and cleaning out the debris.
    Overall, its bit green with a little algae on the bottom, but looking alot better than anticipated. Pool guy agreed it was in good shape, which is nice to hear.
    Thoughts?
    16' x 32' Inground Vinyl Pool (17,000 Gallon)
    Hayward Pro Series Sand Filter + 1.5hp Super Pump, Hayward H300 300,000 BTU Heater
    (2) Jandy 3-Way Valves, (1) Variflo XL Multiport
    (2) Returns, (1) Main Drain, (1) Skimmer, (2) StairJets w/ 1.5" Schedule 40 PVC Plumbing
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: We're Back!
    Sounds like you have a pretty good handle on things....except why such high cya?
    I don't see a SWG in your siggy line so your CYA should just be about half that. Pool School - Chlorine / CYA Chart
    Welcome back
    Yip
    Jul 2015
    Central NJ
    55
    Re: We're Back!
    Quote Originally Posted by YippeeSkippy View Post
    Welcome back
    Yip
    Yea... my memory is a bit fuzzy on the CYA... I remeber always wanting ot get it lower, but it was in a good enough spot. I believe you're right. Thanks!
    Jul 2015
    Central NJ
    55
    Re: We're Back!
    Got two boxes of Borax in tonight... going to let that cook and then hit it with the 12.5% doses in the AM for full on SLAM to get back to where we need to be.
    Jul 2015
    Central NJ
    55
    Re: We're Back!
    SO --
    Added 3.3 bottles of 12.5% shock in around 7a.
    7p comes, and Im sitting at TC of 3 (FC=2.5, CC=<.5).
    Seem right? Water DEFINITELY cleared up... just not sure if I need to maintain the FC target of the initial SLAM anymore, or target 8 or so and carry on?
    Should I be pitching in a bit more shock/bleach to bring levels up and pass a OCLT?
    Jul 2015
    Central NJ
    55
    Re: We're Back!
    Hopefully I answered my own question right -- added the leftover 3qt of Shock and will do another TC test before bed and one at first light for a OCLT.
    Jul 2015
    Central NJ
    55
    Re: We're Back!
    Looks like my FC went UP by one overnight? Perhaps my testing was off by a few ml, but I'd say it's clean and looking good! Time to get that vac out!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,412
    Re: We're Back!
    Nice to see you have it covered! How does your water look? Can you see the screws heads on your main drain covers?
    Kim:cat;
    Jul 2015
    Central NJ
    55
    Re: We're Back!
    Good question! I didn't think to note visual of the screw heads (good check!), but it looks crystal clear, if you look past the little areas of matter leaves and debris I need to clean out. I can see the seams on the bottom of the liner in the deep end, so I'd say thats pretty clear!
    Jul 2015
    Central NJ
    55
    Re: We're Back!
    My pool has a bunch of hefty leaf+other debris that needs to be cleaned out. Should I just hook up the vacuum and run this to waste in the yard? My filter doesn't seem to have alot of suction to make this efficient... perhaps I need to adjust the valves a bit...
