Results 1 to 10 of 10
Thread: First meeting with PB this week -- any advice?
    Sep 2015
    Atlantic Beach, FL
    70
    We've chosen a PB and will meet with him Thursday. We'll be going over what we want, then he'll come back later with a detailed contract. (We already have the initial estimate.) Any words of wisdom for this first meeting? Anything you wish you'd asked right off the bat?
    I'm also attaching a rough sketch of what we're thinking. Tiny yard, tiny pool McDonald_Pool_Kidney_May14.jpg
    8K gal 13'Wx19'L IG kidney. 3.5' to 5'6" depth. Pentair: Ultratemp 120 heater/chiller; Intelliflo 2 VS pump; Intellichlor IC40 SWG; cartridge filter; EasyTouch controller. 3 wall returns, 1 skimmer, 1 cleaner line. Tremron Oak Run coping and pavers. Noble Tile Toscano waterline. Marbletite's Freestone pebble in St. Thomas. TF100 and K1766 test kits.
    Sep 2015
    Atlantic Beach, FL
    70
    Re: First meeting with PB this week -- any advice?
    Signature revised to reflect latest plan.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    I would be most interested in number of skimmers and returns. In a tiny pool it's not as big of a deal, but I would prefer at least 2 returns and one skimmer. Skimmer on the down-wind side.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Sep 2015
    Atlantic Beach, FL
    70
    Three returns and one skimmer.
    Winds are usually from east (we're three blocks from the beach, so normally blowing in from the ocean), so we should have the skimmer on the west, correct?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Sounds perfect. Post pictures!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Does he know you've chosen him? I would normally recommend giving requirements/specs to each builder to have them give you detailed quotes so they might be somewhat comparable. Then you tend to have more bargaining ability.
    Have all equipment that you want picked out so he can give you exactly what you want. Same for as many other details as you can think of. Some would be waterline depths, exact dimensions on everything, per square foot charge for increased decking (MANY people increase from original plan and then is not he time to negotiate a rate), how many lights, what kind (you can specify), etc.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    If you have not already done this - draw out the pool on your yard to get an idea of the size and shape to make adjustments. Size can affect price.
    Also get pricing for any and all options that you may even be slightly considering. Like an upgraded paver material or plaster - iron out the pricing for those things right at the begining. Once project starts, PB's tend to be able to quote a higher margin since we are a captive customer already.
    Good luck!!
    And yes - like Mr. Bruce said - we love pictures!!
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Sep 2015
    Atlantic Beach, FL
    70
    We've talked to six companies over the last six months, and got estimates from three. The estimates were as apples-to-apples as we could get them at this early stage. One PB was eliminated because the salesperson suddenly went dark on us for 17 days, so we took that as a very bad sign. The other one we eliminated had a price about 30 percent higher than the others, which was enough of an increase that we'd have to omit a few things. The one we're going with (and he does know we've chosen him) had the lowest price (but not crazy low), but more importantly, we liked him, saw that he understood us, and we've been to see his work. I've also contacted his references, and they seemed to be honest since they told me what went wrong and what to watch out for while they still recommended him.
    Hubby removed an old deck and our hot tub, and once the concrete pad it was on is gone, we'll be marking out everything on the ground.
    The PB's price also included pavers and wall labor and materials, but we're probably going with less square footage on the pavers than he had in his estimate, so we should be good there unless we ultimately pick some overly snazzy kind
    One thing to be decided is the Premix Marbletite or the Pebble Tec finish, as noted in my sig.
    Thanks everybody! I'll take all of the thoughts/opinions I can get.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Sounds like you had a good process to work through the bids. If you have less S.F. of pavers, how will you know what credit you are due? I recommend an agreed upon rate for an increase or decrease per SF.
    Sep 2015
    Atlantic Beach, FL
    70
    That's a good question, bmoreswim! The PB does not yet know that we're thinking about less paving, so I'll find out in the meeting what the price per square is first. Thanks for the advice.
