Thread: help ! aquabot has new belts, won't move
    lindaspoolboy's Avatar
    north NJ
    23
    after replacing the drive belts on my aquabot, it wont move at all.
    (actually, it will crawl on the wall a little, but once it hits the bottom, it cant move)
    it seems that the brand new belts are not tight enough ??
    could the cause be stretched drive tracks ? (they haven't been replaced in a couple of years )
    thanks in advance,
    lindaspoolboy
    [attachment=0:2s7xpuqx]aquabot1.jpg[/attachment:2s7xpuqx]
    29,000 gallon vinyl IG, Hayward 1.5hp Pump, DE Filter.
    Jun 2008
    Scottsdale, AZ
    37
    Re: help ! aquabot has new belts, won't move
    Are you sure that you replaced the belts properly? Could be the motor if you think everything else is good. Do you hear the motor engage? Do you see the sprockets trying to turn?
    Gary
    18 x 38 28800 gals gunite inground;Purex Triton High Rate Sand Filter;1 HP 2 Speed Hayward Tristar Pump; Raypak Heater
    Aquabot Bravo; Goldline Aqua Logic Controller/SWG
    north NJ
    23
    thanks for the reply.
    the belts sure look like they're correct (thats why i included the photo)
    the motor is engaged. the center sprocket is turning
    Mar 2008
    Los Angeles, Ca
    222
    You might want to check out this page
    http://www.i-love-my-aquabot-automatic- ... -belt.html
    There is also a button on the left to click for troubleshooting aquabot problems.
    My aquabot broke a couple years ago, so I can't look at it any more. The drive motor broke, and for the replacement cost, I couldn't justify repairing it.
    But, from what I remember, one of your bushings might be backwards. The bushings are the white things in middle of the drive belts, that create tension in the belts. I think one should be opposite of the other, and they look like the are both in the same direction in the picture.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Hi,
    It looks like the bushes are the correct way around from the photo. May be check that the rollers are fitted into the side plates correctly. If the pink belts are slack then there is obviously something not fitted correctly.
    www.kal-tech.co.uk
    Check to make sure pulley assembly is not worn down causing to much slack in the belts.
