Thread: Out of level and wonder how to move forward...
    May 2016
    DeSoto, KS
    1
    Soooo... I just purchased my first pool. When we selected its location, I appeared mostly level. When we measured, it was about 2 inches out of level, so a half-hearted attempt to dig and level was made. However, when the pool was setup and filled, it's 5-6" out of level... I know I need to drain it and relevel, but:
    1. I need a recommendation on finding a professional to do the ground work,
    and
    2. I'd like to save the water.... Is there any way to do this?
    Kelly, above ground Coleman: 18' X 48"
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,224
    Re: Out of level and wonder how to move forward...
    A landscaper could level the ground for you, or most any builder type. You can use the water to irrigate your yard by sinking a hose in the water, stick your thumb over the end, then drag that end out, hold it down to the ground, and let go (like a siphon). Can't think of any way to save it. Glad you're levelling the pool and welcome to TFP
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    1. almost anyone that does yard work or landscape company, you can also rent a lawn sod cutting machine to dig down
    https://www.google.com/search?q=DeSoto%2C+KSsi:13748313083513058420
    2. The only way I know how to save the water is to transfer it to another pool
    I hope this helps
