Thread: Saltwater and my lawn
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    I was just wondering if my saltwater pool is doing any long term damage to my lawn or soil. I have an Intex pool that gets drained and stored every year. That's a lot of salt that keeps getting absorbed into the lawn. If I keep doing this year after year, will all that salt eventually cause harm to the soil or grass? Been doing this for 5 years and my lawn still looks as healthy as ever.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    JoyfulNoise's Avatar
    May 2015
    13,176
    Re: Saltwater and my lawn
    It's not as salty as you think and grasses (especially those used on lawns) are very hardy. As for salt build up in the soil, the answer is - it all depends...
    What is your drainage like? How much rain do you get?
    You live in IL where the average precipitation (rain and snow-melt) is pretty high. If your lawn has good drainage, then the amount of rainfall you get every year should be more than adequate to wash away any sodium chloride build up.
    Matt
    Jun 2014
    Roseville, CA
    343
    Unless you have a water shortage and are expected to conserve water, I would not recommend draining it onto the lawn. I use a clean out port in my house below the kitchen sink and pump it into the waste plumbing.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Aug 2010
    Dallas, TX
    4,052
    I backflush my saltwater pool onto my St. Augustine lawn in the Texas heat and have not had any problems.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    My saltwater pool overflow goes to my lawn, about half bermuda grass and half weeds and it grows better there than the rest.
