Thread: Chlorine demand still high after months of slamming
    Sep 2015
    London
    4
    Hi,
    my hot tub is consuming 2ppm per day FC and CC is above 0.5
    using lamotte commercial 7 testing kit
    hot tub had been standing for a few months with residual water in the pipes after the pump broke and I emptied the tub
    after refill i have been slamming. Cya is zero, the bugs ate it when fc dropped to zero when I couldn't keep up slamming.
    i even hyper chlorinated to 50ppm but still the demand and high cc exists
    i will change the filter again but what else can i do? Change water? It has only been a few months since i recommissioned
    it is becoming tiresome now.
    Our pool is behaving perfectly...
    thanks
    malcolm
    our hot tub is 980 ltrs Toronto spa from canadian hot tubs
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Chlorine demand still high after months of slamming
    The only other thing to do is get some ahh-some tub cleaner and give it a good cleaning. But, 2ppm per day isn't all that bad.
    Sep 2015
    London
    4
    Hi, thanks for the feedback.
    i looked up what ahhsome is. I'll try to get some in the UK.
    i thought anything above 1ppm loss per day was bad, esp. combined with high cc
