Results 1 to 7 of 7
Thread: Replacing inground Anthony pool light .
    May 2016
    Kutztown, pa
    3
    I have a 1988 inground Anthony pool with a wet niche pool light . Only numbers I can find on light are E-581424 model number 30. Light has been burned out for a few years . Since we had the pool drained this year I decided to replace it , but am having a very hard time locating its replacement . Please help .
    Aug 2015
    Folsom Prison, CA
    124
    Re: Replacing inground Anthony pool light .
    I am dealing with an obsolete niche as well. Most of the advice I have gotten so far is wait until you refinish and have a new one installed. There are some universal lights out there that adapt to different niches, but the inner ring on mine is all bound up so not much I can do there. The universal lights will run you about 400-600 bucks if you end up not being able to replace the niche.
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
    Apr 2013
    Sacramento, CA
    2,769
    Call Inyo Pools or Sun Play, they answer the phone and talk to them. They can be very helpful in giving you some choices.
    May 2016
    Kutztown, pa
    3
    Funny, I called inyo pools and they sent me here .
    Apr 2009
    Northern Virgina
    55
    Poolcenter sells parts for the Anthony Model #30 light:
    Parts for the Anthony Swimming pool light, Discount Parts For Anthony pools pool light
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    Aug 2010
    Dallas, TX
    4,052
    The IntelliBrite LED fit my 1957 niche.
    Want to see an old light?
    May 2016
    Kutztown, pa
    3
    Thanks for all advice . I now at least have a starting point .
