Thread: Ph and alkalinity
    Jun 2014
    Newporr,ca
    42
    Ph and alkalinity
    My pH is 7.5.
    My chlorine is 2.
    My calcium is 200.
    My alkalinity is 40.
    How do I raise the alkalinity to 80 without raising the pH using bicarbonate?
    1500 gallons SPA. 104
    IG, Plaster, 6years old.
    Sand filter Triton ll TR140.
    Taylor K-2006 Complete Pool
    Pentair brominator feeder using bromine. Bi-carbonate. Calcium chloride.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Ph and alkalinity
    Baking Soda has very little immediate effect on pH. High TA will push ph up over time.
    Plug your numbers into poolmath and see what the dose of Baking Soda should be. Then scroll down to Effects of Adding Chemicals and enter that amount there. It should give you a close approximation of what the baking soda will do to the pH.
    Jun 2014
    Newporr,ca
    42
    Yes I was wondering how I can calculate the dosage needed for alkalinity and also see the effects on the pH as well. How do I do that?
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by whitemok View Post
    Pool School - PoolMath explains how to use http://www.troublefreepool.com/calc.html Take the time to read the article, don't just rush off to use poolmath. You might miss some of the features otherwise.
    Jun 2014
    Newporr,ca
    42
    OK thank you for your time
