Results 1 to 9 of 9
Thread: Continued from introduce yourself.
    So.....after watching the pool dance around with all 5 of the kiddos swimming
    yesterday and getting more gray hair, I called intex and asked all the questions
    about setting up the pool they leave out,
    like where should the seam that ties the sides to the bottom of the pool is supposed to be located.
    she was a little dodgy on that answer ( half as side wall half as bottom?)
    how is the liner supposed to sit in relation the the legs on the pool,
    she stated the liner should touch-press against the legs from tee bar to the bottom of the legs.
    Unfortunately this is not what my pool is doing ATM the bottom half of leg supports is touching the liner.
    my question is what is my malfunction? Pavers to high in relation to bottom of the pool?
    Or is it something I'm not aware of I'm missing?
    any help is welcomed.
    thank you
    16x48" round intex above ground ultra frame
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Continued from introduce yourself.
    Welcome to TFP
    A picture is worth a thousand words, is there any way you can upload a pic to see what you have going on..
    image.jpgSo here is one
    image.jpgNot done with the yard or deck but the kids don't seem to care...lol
    So what do you think legs higher or lower?
    May 2015
    Wichita KS
    29
    That's basically what mine looks like, and it has been fine
    Coleman 18'x48' AGP
    Intex Krystal Clear Sand Filter Pump 2800GPH
    Intex SWG
    **Under Construction** :)
    The top rail wiggle like jello? I'd say inch inch and a half total wiggle.
    Jul 2014
    Oakbank, Canada
    389
    Your good!
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    jmcdtucson's Avatar
    Jun 2014
    317
    It looks fine to me. Those pools are made to flex. It looks like the pavers are roughly level with the bottom of the pool?
    If so you're fine.
    Otherwise the only concern I might have is whether the pool is level from side to side (within 1").
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
