Thread: Heater recommendation
    Jul 2014
    Manhawkin/ NJ
    82
    Looking to install a natural gas heater on my pool. It's an inground vinyl I think about 15000 gallons. It will be salt water, pool gets full sun all day long. Just want it for when we have party's in case it is cold or rainy the week leading up to the party. Pool thermometer says im already at 80 degrees and I'd maybe wanna raise it to 86 during a party any advice on what size, I realize every one here speaks highly of Rheem so if like to stick to them if that is my best bet. Thanks in advance
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Heater recommendation
    Actually, everyone here recommends Raypak for gas heaters. Bigger heats faster. Get the biggest one that your gas service will support. 400k btu is the biggest.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Raypak/Rheem for the win. 400K BTU is best and don't buy into any of the curpo-nickel hype on the heat exchanger because you have a salt chlorinated pool.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jul 2014
    Manhawkin/ NJ
    82
    So raypak and Rheem are the same right
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Yes they are the same. Rheem is a special badge that Raypak puts on some of their heaters in certain markets sold thru select dealers, but they are the same exact units.
    Paul
