Thread: Getting Ready to Convert- Help Needed- A Few Questions
    May 2016
    us
    8
    Ive been using Baquacil for several years so my knowledge of the water chemistry, etcis lacking
    When we took the cover off the pool this year, it was more green than previous years. Like others, last year the water was cloudier than previous years so Ive decided to move on from Baquacil. Ive been reading this article but just trying to retain everything http://www.troublefreepool.com/conte...ol-to-chlorine
    I just want to make sure I understand this correctly
    1. I will increase my ph to 7.2-7.4
    2. I have a 15,000 gallon pool. The calculator shows that I will need to add 468oz of household bleach (8.25%) to bring the FC from 0 to 15
    3. Test it as frequently as possible and add whatever amount I need to get the FC back to 15
    4. Once I lose 1ppm or less overnight, change my sand in my filter
    I have a few questions though
    1. I know it says to add X amount to get the FC back to 15 as frequently as possible. Can anyone give me a ballpark number of how fast it drops or how many days to convert so I know how much bleach to buy? For example, its basically telling me to start with about 5 jugs of bleach. Should I anticipate needing 5 jugs every hour to get back to 15 FC or 1 jug, etcI just dont know how fast that number will fall, how many days, etcand want to make sure I have plenty on hand. I just dont know if Im going to need 10 jugs of bleach or 100
    2. It says,Your conversion is complete when CC's are 0.5 or less two days in a row What does CCs stand for?
    3. Also, can someone point me to a good thread here that shows what chemicals I should be adding to maintain after the conversion is complete
    Thanks for the help!
    Jun 2014
    15,292
    Re: Getting Ready to Convert- Help Needed- A Few Questions
    Hey Scooby, and welcome to TFP! You have most of it down correctly, and definitely keep that page bookmarked. It works. A few comments:
    For item 2 - The calculator was giving me 333 ounces (2 gal & 2 quarts) to go from 0-15 for a 15K pool. Might want to double-check.
    Question 1 - So hard to know for sure. You can expect to go through a lot more in the early stages, then once the heavy stuff breaks-down and thins-out you should see FC begin to level-off and not drop so much. Me personally, I would ensure I had at least about 15 - 20 gallons on-hand to start and go from there. That's just my personal wag.
    Question 2 - CC is combined chlorine. Once your FC sanitizes the water, the residual chlorine becomes CC which is waiting to be oxidized by the sun.
    Question 3 - Look at the links below in my sig. They are also available from the Pool School page. Hope this helps. Take lots of pics, and good luck!
    May 2016
    us
    8
    Thanks for the quick reply!
    A few things.
    Im showing 468oz. going from 0 to 15 on 15,000 (see photo)
    I ordered the Taylor K-2006. Do you think that is overkill and should I get just a more basic testing kit?
    Quote Originally Posted by Texas Splash View Post
    Jun 2014
    15,292
    You need the K-2006! Definitely. I'm not seeing a photo though, but I am on a work server computer. No matter what, I still come-up with the 333 ounces of bleach though. Are you using the calculator like this one: Poolmath calculator ?
    Did you manually update the "Weight" block and change it to "8.25"?
    Ahhhh haaaaa! That was it. The weight.
    May 2016
    us
    8
    Got it. Awesome. Thanks!
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    465
    If you are able to bump your level back to 15 every daylight hour for 2 days, the heavy lifting could be over within a half week. OTOH, every pool is different depending on features (ladders, light, stairs etc) and starting BQ levels. One thing is absolute: frequent testing is a must. Check out my sig. I convert last year.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 29k gal., 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
