Thread: Testing Samples Indoors
    phenwick's Avatar
    May 2009
    Metro St. louis Mo.
    11
    Are there any down sides to collecting a plastic cup of pool water and running the test indoors in the kitchen?
    Would the indoor lighting, if testing at night, affect the readings? Any other problems?
    Thanks
    Dave
    Dave
    22,000 IG vinyl; Swim Out; Sand Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Testing Samples Indoors
    I frequently test indoors. I try to use as much light as possible. My fridge is white so that helps for background use.
    Jan 2009
    Cupertino, CA
    1,966
    For color-matching tests like pH and the OTO (yellow) chlorine test, indirect natural light against a white background is best; easy enough to achieve that indoors. If it's not practical to test during the day, indoor lighting probably won't lead you too far astray, although I have no technical or personal experience to back up that thought.
    For titration tests like FAS-DPD or TA or CH, you just need enough light to be sure of the color changes, the exact colors are not important.
    --paulr
    BBB "Intermediate Swimmer"
    Guest
    I would suggest reading the CYA test outdoors in open shade and the LaMotte borate strips really need to be read in sunlight. I have yet to find an artificail light that will give an accurate reading with this particular strips.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I test in doors like FPM. We have a micro wave above the stove with a light that I use so I can see the test results. On PH tests my wife calls the shots on that reading because my eyes aren't all that great and she is better at color than I am!
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
