Thread: Salt to high on Hayward t15
    Cookierx1's Avatar
    May 2016
    Jasper Alabama
    1
    I have just changed my Hayward T15 thermistor after doing so and cleaning my cell very well it has continued to read high salt when it is absolutely not high. It's actually almost perfect. I have a liquid chemical test kit its reading 3200 on the kit but on the generator it's saying 4400. I've tried to recalibrate the generator and the numbers will not even go below 4400. It has been an exceptional product until maintenence this season. There's no visible problem with the generator itself since we've replaced the thermistor because there was no power lights and it was demolished after taking it out. We ordered the thermistor online from the place recommended in this forum. After the 1st couple days it worked awesome. So I'm stuck as to what to do. Also drained some of the water put fresh water in all other chemicals are excellent. The readings are wonderful for now but without generation they won't be for long. Sorry to ramble but I tried to include everything I thought someone may ask. I have an 18X36 vinyl liner inground swimming pool I have a Hayward 1.5 horsepower pump also have a Hayward booster pump and I have a 250 pound sand filter by Hayward.
    Mrs Grace Thompson
    Jun 2011
    Long Beach, CA
    2,790
    Re: Salt to high on Hayward t15
    Welcome to TFP!
    Please post the complete set of diagnostic numbers.
    38,489
    Is the SWG complaining about high salt? If not, I would roll with it
