Results 1 to 8 of 8
Thread: From green to cloudy, need help!!
    Jul 2015
    Bridgewater, Virginia
    17
    Hey guys, so we just opened up our pool couple days ago, it was green from the winter, we added well water to it, to fill it to skimmer. Dumped 4 bottles of bleach in it. Have the pump running 24/7, the water is cloudy now. We also have a swg and added I think it was 3 bags of salt, have the swg running for 7 hours a day. I just took test today, here are the number.
    FC-.6
    CC-2.6
    PH -7.5
    TA- 120
    CYA - 0
    I know I need to increase FC and get the cc dobwn. Also need to increase cya. What should I do. Add whole bunch of bleach? And start adding the stabilizer?
    Any info would be appreciated.
    Thanks!
    AG 24' by 52" (13,600 Gallons), Hayward vari-flo XL valve sand filter-S190TSCP, Hayward power-flo LX pump-1HP.
    Jun 2014
    15,205
    Re: From green to cloudy, need help!!
    Can you first confirm for us which test kit you are using? It helps to know that so we can picture how you are doing things there.
    No stabilizer just yet.
    Jul 2015
    17
    Quote Originally Posted by Texas Splash View Post
    I'm using the Taylor k-2006 kit.
    Aug 2010
    Dallas, TX
    4,052
    Why did you add salt? I don't see a salt test figure there.
    Honestly, you need to SLAM your pool. SWG should be off during this time.
    Pool School - SLAM - Shock Level And Maintain
    Use the 10ml test for FC (FAS-DPD). The precision of the 25ml test is not necessary.
    Add enough stabilizer to get you to 30ppm
    Jun 2014
    15,205
    Good. Based on your circumstances of winter green water, no CYA, and an elevated CC level, I would recommend you have a good amount of bleach readily available and do the following:
    ** First - lower pH slightly more to about 7.2 ** THEN .....
    1. Begin a SLAM and dose FC up to SLAM level. If your CYA test is showing as zero (perhaps already converted to ammonia), use a SLAM/Shock FC of 10. Do not add additional CYA at this point.
    2. Retest FC at 10-minute intervals.
    a. If FC loss is greater than 50%, add FC to bring back up to SLAM level and continue retesting FC @ 10-minute intervals.
    b. IF FC loss is 50% or less, add FC to bring back up to SLAM level. Go to Step 3.
    3. If CYA is below 30 ppm, add enough CYA to bring level up to 30 ppm.
    4. Continue SLAM as directed in the SLAM article until the SLAM Criteria of Done are met. Test as directed in the SLAM article - no longer need to test FC at 10 minute increments at this point.
    Jul 2015
    17
    We added salt, because we turned the swg, figured it would add chlorine to the pool. Is that a no no? Should I keep it off until all numbers are where they should be?
    Jul 2015
    17
    Also we have another dilemma. We are flying out of country on Thurs, for 3 weeks. I will have my nephews here, house sitting and all. What's the best thing to do with the pool?
    Btw, opening the pool was not my idea, my husband insisted that we open it. I knew we wouldn't get it cleared up in time. If only husbands would listen to their wives!!😉😒😞
    Jun 2014
    15,205
    Well, not much really without consistent testing. Everything may just go on hold until you get back. Don't forget to bring us all back a souvenir.
