Thread: Installing replacement liner inside of Intex 18' metal frame
    May 2016
    Demotte, IN
    3
    Re: Installing replacement liner inside of Intex 18' metal frame
    Sorry to hijack your thread, but I also have a leaky seam issue on my Intex 18x52 metal ultra frame. It is brand-new, just out of the box for 2 days. It had less than 2 inches of water in it when we noticed the tarp had small puddles forming in several spots around the pool. I don't know if it's one or several leaks. The ground is miraculously level and free of any debris, so I know that's not the issue. I figure since it's brand new with potentially several leaks, the whole seam may be defective and an overlap liner would save a lot of the headache that's bound to come with trying to patch inside the little flap on the bottom seam.
    Before I take the new overlap liner leap, I was wondering if there was possibly some vinyl sealant product that I could paint or smear or caulk inside around the bottom and center seam to seal that little flap down ? Wet application or dry; there's only an inch of water in it so it wouldn't take much to dry it. I don't know if they make a product that will bond to the vinyl and stand up to the chemicals, but I imagine it would be cheaper and easier to try that first.
    Any thoughts are appreciated !
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    If it's a new pool it should be under warranty and just call intex or whatever Mfr. for a warranty replacement.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
