Results 1 to 18 of 18
Thread: Is my pool stained?
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Exclamation Is my pool stained?
    Levels are all okay - water coming out is clear - backwashing shows barely dirty water and only for a few seconds to clear back up - POOL IS GREEN! Nothing coming off the bottom of the pool when sweeping/netting/leaf sucking
    Only thing that was low was my CYA which I've added CA for that.
    No reading done today.
    Could I have staining?
    Pool was not covered over winter
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    Jun 2014
    15,137
    Re: Is my pool stained?
    Green means one of two things ...... metals in the water (i.e. iron/copper) or algae. We definitely would need to see test results performed by you with either a TF-100 (link below) or Taylor K-2006 test kit to know if you have algae. Do you have either of those? Since you are on a well, it is very common to have metal from well water. If the metal is permitted to precipitate out long enough it can indeed stain the surfaces. You should probably read the TFP Pool School - Metals in the Water and Metal Stains page.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Oh I didn't even think about the metals in my water!
    I will do a run down of tests (minus CYA bc I'm out of fluid as of the last test I did) and haven't received new bottle yet.
    Lynzizzle
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    FC: 2
    CC: 1
    TC: 3
    TA: 220
    CH: 175
    Last CYA reading: 25 - added 4 lbs to bring up - can't take reading as I ran out of testing fluid. It's in order tho.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Also - after adding cya the filter pressure keeps going up to 25 psi and the jets stop pushing water as hard and the skimmer basket in the pump doesn't have water sloshing around through the little window (if that makes sense). Have to turn off pump, release air pressure inside the slimmer basket and restart pump for the jets to function normally.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Did you add the CYA in a sock as shown here, Pool School - Recommended Pool Chemicals.
    What kind of filter do you have? Better yet how about putting your pool info in your signature as shown here, Pool School - Read This Before You Post
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    No - half in skimmer half distributed over deep end - didn't have a sock to use and have to order them around here.
    My info is at the beginning of this thread. It doesn't carry over when I'm mobile aka not in a desktop.
    DFW, TX
    24,496
    It will post from mobile device too, just need to click show sig box on all devices.
    Any tube sock or knee high will work fine in the future. Don't backwash the filter until the CYA shows up on the test or it will get backwashed out of the filter.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    That's at least a week from now
    Lynzizzle
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    A picture will help us and what is your PH? Green and clear=can be metals, green and cloudy=algae and you could still have metals.
    Backwash when pressure rises 25%. Hopefully the CYA will mix before you need to backwash. Make sure to brush on the deep end well and often as the CYA can stain your pool.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    DFW, TX
    24,496
    You can test about 4 days after you added to see where you are. Or backwash now and add some more in a knee high.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Ph: 7.5
    had to backwash last night. I dont want my pump to burn up. Will be doing a deep clean of the filter as soon as my husband is home before dark. He has to loosen the couplings on the plumbing lines so i can get the valve off.
    Lynzizzle
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    FC: 15
    CC: 1
    TC: 16
    PH: holding at 7.5
    Jul 2012
    Saugerties, NY
    447
    What does the backwash water look like? If you have clear, but green water in the pool, and a rusty backwash, you have iron.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Houston, TX
    1,099
    I have a ranch w a well and the galvanized pipes will certainly tell you if you have Fe [Iron-Ferric] or CA [Calcium] in your pipes. If you have PVC, you won't get build up in your pipes like galvanized, but they will become discolored or darken reddish-brown.
    Well questions for you:
    Have you ever tested your well water?
    What type of well tank do you have? Fiberglass or Metal tank?
    Also, when you test your well water, you have to run your water long enough to flush your pipe lines and possibly even your well tank depending on what it's made of and how long the water has been in the tank before you use it.
    Does your toilet bowls have stains in them or rings at the water-line down? If so, you have Iron in your water for sure.
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    I have given up on the water for this year. For next year, we will be draining the pool and hopefully having it acid washed before refilling it. Also will be getting a hose filter, to filter out some of the metals.
    Lynzizzle
    DFW, TX
    24,496
    An acid wash is very aggressive. It will remove a layer of plaster and shorten the life of your plaster. It might be better to try a no drain acid bath first. Here's how, The Zero Alkalinity Acid Treatment
    DFW, TX
    24,496
    Are you sure your pool is plaster and not vinyl? The pics looks vinyl. An acid wash would ruin a vinyl liner instantly. You can look up your pool info on your county tax records. It will tell you year built and possibly more info about the pool.
