Thread: help. pump won't start.
    May 2016
    Arlington, TX
    224
    I have a Hayward Super Pump II (2HP) that I had to get the pump seal replaced on. I did the rest of the gasket kit too. When I went to put it back, it just hums and won't spin. I pulled it out and started it and it worked outside the housing so I thought I had it bound. After numerous attempts I realized that it was coincidence that it worked outside and not inside the housing. Once it tripped my breaker. So now I see even outside the housing with nothing to possibly bind it, it just hums. Shaft turns freely. I know Leslies took one of the capacitors off to get to the shaft to remove the impeller. Is it possible it is damaged or maybe hooked up wrong? I am getting ready to ensure my wiring is correct but I am sure it is since I took a picture of the 220 connection before for reference.
    Thanks for any assistance. I tried getting someone out but I can't even get anyone to return my calls. I know this is a busy time for pool guys.
    scott
    May 2016
    Arlington, TX
    224
    Re: help. pump won't start.
    Quote Originally Posted by scottsams View Post
    scott
    I got it. Turned out I knocked the centrifugal switch off kilter when working on it. Took it off and put it back on and it started right up.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Nice save!
