Thread: SWG reading Low Salt when I know that not to be the case
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    It's a Hayward Goldline Aqua Logic AQL-PS-8 system with the T-Cell-15 cell.
    Question is: Does reading a lower salt level on the computer than what is actually in the pool indicative of a cell going bad or does it just die in one shot? I can still make Chlorine, but I had to raise the salt level significantly to let the cell "think" I am in the right range.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2011
    Long Beach, CA
    2,778
    Re: SWG reading Low Salt when I know that not to be the case
    The first thing to check is to make sure the cell is clean of scale.
    If it is clean of scale then there is a good chance the cell is starting to wear out if the salinity readout is significantly lower than the actual number.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Thanks Ping. I forgot to mention. I did clean off in a diluted acid solution. It didn't help. I think it's time for a new cell.
    Jun 2011
    Long Beach, CA
    2,778
    Leslie's usually have testers for Hayward cells if there is one by you.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by ping View Post
    Good call. I had it tested and it failed. It doesn't say why it failed. The result is either a pass or a fail. No in between. New cell ordered (online company) and is on it's way. I got 6 full seasons with the original genuine T-Cell-15. I only got 4 from the after market replacement (CompuPool). Needless to say I spent a little more this time and got the genuine again. The CompuPool was a cool design because you can see through the cell and see the chlorine gas being produced. But if the life isn't as good, not worth it.
