Results 1 to 9 of 9
Thread: Need help with landscaping ideas
    May 2008
    Southern Connecticut
    56
    Last year we put in the aboveground pool and this year is the landscaping. We are planning on putting hostas around the back side of the pool and around the deck and walkway. Our backyard is on the slight slope so when they put the pool in there is about a 2 foot gap between the pool and grass which is also about a 2 foot drop. I have no clue what to do with this area. It is constantly collecting leaves in there. Here are some pictures to show what I'm trying to explain.
    18' Willow round AG 52", 19" Sand filter 1 hp pump, Intex SWG 8110, Bought and install May 08
    New 12'x16' deck built March 09
    Poss thinking about solar panels next!
    Jun 2008
    Carrollton, GA
    88
    Re: Need help with landscaping ideas
    Hello,
    Our yard is also on a slope. About 3 feet from top of pool to back side. We just added river rock for drainage. This works very well as about 15 foot from the back side of the pool is a wooded area. It looks very clean as we have to constantly keep on top of the weeds. The pump is also on this side of the pool. We want to put the pool deck all the way around eventually but not in the budget right now since hubby lost his job after 34 years (2 years from retirement).
    Susan
    18x33 AGP, BAQUAPURE 200 lb sandfilter, 2 1/2hp Workhorse pump (2 speed)
    May 2008
    56
    Can I put river rock there or maybe pea gravel? I thought I couldn't be anything against the side of the pools.
    Jun 2008
    Carrollton, GA
    88
    Hello again,
    Yes you can.
    Susan
    May 2008
    56
    Do you have any pictures?
    Jun 2008
    Carrollton, GA
    88
    No I don't have pictures since we added the river rock. It has been raining here for the most part for about 6 wks.
    Also you need to get some total vegetation killer and spray it around the outside perimeter of the pool so the grass does not get under pool and start growing through the liner.
    Susan
    May 2009
    Tidewater, Virginia
    1
    Hi,
    Make sure you decide if you want to put plants IN the ground, before you spray. A total vegetation killer can last as long as a full year, which would kill the chances for most plants to be healthy (or even live) Then there are the roundup type herbicides that you can spray and plant in the area right away. Plants add beauty and screen plumbing, but you have to spray every other week or so to keep the grass away like the previous member said.
    The types of plant material you could use in this application depends on the area you live and of course, personal preference and lifestyle. Some beautiful plants require lots of maintenance. There are some plants that have roots you can contain, but most uncontained plants , by nature, seek out water.
    Have you considered using rock like the member suggested? Then you can use the area for groups of pots. You can show off a selection of neat pots, use different color groupings for different holidays, etc...I would use marble chips if I was considering white rock. Marbe chips will not turn to that dirty rusty,gray color. It stays white, but costs more.
    Hope this helps a little,
    ODUlady
    11300 gal vinyl 15x30 52" Above ground
    Sand filter
    1HP Pump
    Willamette Valley Oregon
    Jun 2008
    Carrollton, GA
    88
    Here are pictures.
    May 2008
    56
    thanks for ideas....i just realized that the reason we didnt do anything with the area last year was because of the codes in the city. We can't build that area up. so i figure i will just put hostas around the top and over time you won't see the drop down.
