Thread: Thank you!
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Thank you!
    A BIG Thank You to all of the experts on this forum. Because of all of the information on Troublefreepool.com, I was able to oversee the construction of our pool, maintain pool equipment and keep the pool balanced! Most recently, I searched and found how to repair my Pentair Actuators. Both went out within a week of each other; however, I found on this forum that is was probably the micro switch. I purchase for $1.76 a piece, replaced them and they are now working perfectly!
    This forum has saved us $$$$. Just can't say thank you enough. Keep up the good work!
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Thank you!
    Glad to hear it! Pool owners helping pool owners.
    I hope you'll consider becoming a supporter as well. CLICK HERE to Become a TroubleFreePool.com Supporter!! Added benefits to becoming a supporter is a discount on next purchase at tftestkits.net and at inyopools.com
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Thank you!
    Thanks for the feedback. Glad TFP is working for you and your pool!
    Jun 2014
    15,198
    Re: Thank you!
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Re: Thank you!
    I did see the newest info on TFP supporter; however, I thought I already was! I read through posts and realize that the original Lifetime member is now a Bronze. I will certainly be glad to up my support. Thanks for pointing that out!
    DFW, TX
    24,502
    Re: Thank you!
    You still are, your Lifetime badge is good. If you donate more then you will get one of the new badges too! Thanks for supporting TFP!
