Thread: Need a heavy duty way to keep the straps fastened onto my solar cover
    Jul 2014
    Northern Cincinnati, OH
    56
    I have a ~20x40 kidney shaped pool and a heavy duty hurricane solar cover reel. The reel works great, but need a heavy duty way to attach the straps to the cover. I continually have problems with them pulling off. I/ We manually pull the first 1/3 of the cover up to the reel and then crank it in to reduce stress on the strap mounting points. I have tried various glues and non seem to hold all that well due to the contour of the bubbles in the cover itself. If I had to guess, most of the time the straps come loose during reinstalling/unrolling the cover. Looking for a better long term solution. The cover and reel works great when they stay attached and we keep the pool covered at all times when not in use except for the dog days of summer here in Ohio! Any suggestions are greatly appreciated!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Need a heavy duty way to keep the straps fastened onto my solar cover
    These are the straps I used that came with my Rocky's reel. No issues after a season +this spring. What type of fasteners have you been using so far?
    Isolated Spa - 345 Gallons
    Jul 2014
    56
    Thanks for the reply. I would say that basically this is my setup: Swimline Universal Solar Cover Reel Strap Kit 5100SK
    The little screws pop out of the clips that hold it to the cover. Then ends stay on the straps themselves no problem and no issues where it attaches to the reel either.
    Feb 2014
    Central Minnesota
    5,080
    Thought my link was in the post... Rockys Universal Solar Cover Reel Strap Kit - Walmart.com
    These are more of a rivet than a screw in fastener. Mine haven't budged at all.
