Thread: day 10 from opening pool and still cloudy
    May 2015
    SALISBURY
    3
    Hi
    Today:
    TA =170
    PH= 7.8
    CYA =90
    FC = 25.5
    CC = 27
    I have 19237 gal pool. 459 sq ft. gunite in-ground plaster
    Using bleach
    filter gets clogged with first hour running psi is 30
    Use DE and been flushing filter 2x per day. Haywood DE 3620 filter
    water is very cloudy can only see down 1 foot
    This is day 10
    All suggestions welcome
    Thank you
    Debra
    459 sq ft. gunite inground plaster
    30' x 19.6' 3 to 6 deep, Haywood DE 3620 filter
    Haywood chlorinater holds 20 3" round tablets
    19237 gal. kidney shape, skimmer & main drains,
    Sep 2009
    Frederick County, MD
    184
    Re: day 10 from opening pool and still cloudy
    Debra:
    With CC of 27 (Assuming that is correct) you have a ton of algae in the pool. This is most likely why the filter is clogging so quickly and the pool is so cloudy. Seems like it is SLAM time but lets let other folks weigh in as well.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    439
    I'm having a hard time with your FC and CC numbers. Is the CC number supposed to be TC (Total Chlorine)? If so, it is a sign that you still have organics in the water. How are you testing it? You need to have a good DIY kit (See my signature below).
    Also, if your CYA level is to be believed, it is too high for a non-SWG system (high even for a SWG). If your FC level is accurate, it is also too low for an effective SLAM at CYA=90. Consider doing a partial drain/refill to lower your CYA. Then SLAM the water. But as I mentioned above, you need a recommended test kit.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
