Thread: Heavy Rain. Floating pool liner.
    May 2016
    virginia beach, va
    24
    I have been trying to get my pool right since my husband is deployed and it was finally showing major progress. Just a bit cloudy. Then it rained heavily for 2 days straight. My neighbor came over to turn on the waste function of the pump so the pool does not overflow. I was able to turn off the pump about 930 pm last night. This morning, the level on the pool was just below halfway on the skimmer intake. That is when I saw it... my pool liner is floating from the wall!!! I am at my wit's end.. In tears right now... Is there anything I can do?
    25,000 gallons IG, Hayward Pro series XL, sand filter, built 1996 (i will have to check), well water with dual filtration system, K-2006 kit
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Re: Heavy Rain. Floating pool liner.
    Quote Originally Posted by laarninat View Post
    I had my liner float one winter when i lost a lot of water due to a leak. I was able to get it back in place with the brush as i added water. My guess is with all of the rain your water table is very high and as it drops back down you should be able to get the liner more or less back in place. I ended up with two wrinkles in my shallow end but after dealing with a leak and a floating liner i consider myself lucky!
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    May 2016
    virginia beach, va
    24
    ok. thanks! I hope it isn't as bad as I think it is.
