Results 1 to 8 of 8
Thread: need some trouble shooting for my sand filter
    Aug 2009
    SW Wisconsin
    518
    hey All. I got our pool up and running this weekend, but having some "issues" with our sand filter. It's a Sta-Rite Cristal Flo T-210WF Sand Filter
    and I did the usual backwash and then rinse cycle before kicking it into "filtration" yesterday..but when I turn the level over to the "filtration" mode, I still have some water coming out of the backwash hose. Not a ton, but some. What would cause this? How do I fix it??
    Thanks much
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jun 2014
    15,109
    Re: need some trouble shooting for my sand filter
    It's possible your spider gasket inside is beginning to show signs of wear. Have you been careful to always turn the multiport valve in the same direction, and only switch modes when the pump is in the "OFF" position?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    This is usually a sign of a worn spider gasket in the multiport valve. It is a fairly easy diy fix if you can find the gasket, however some manufacturers are making the valves so you have to buy the top part of the valve assembly. Its still an easy fix, just more expensive than the gasket alone. You can check with a full service pool store and see if they have the part available.
    Love TFP? Become a
    TFP Supporter!
    Aug 2009
    SW Wisconsin
    518
    Thanks for the speedy replies. Texas- I do only switch "modes' when the pump is off. I don't however only go one direction, I use either direction.
    I'll see if I can find the manual and how to remove the spider gasket.
    Aug 2009
    SW Wisconsin
    518
    Here's an illustration for my pool sand filter pump head. What parts would I need to replace to make my multiport fully operation again??
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Quote Originally Posted by flyweed View Post
    Looks like 8, 12, 13, 16 The actual spider gasket is built into 12. The other O-rings might be worn and deformed and could leak after being disturbed
    Aug 2009
    SW Wisconsin
    518
    Yeah..I just bit the bullet and ordered the whole top half...it was $81.00 and included ALL items (1-13)
    Jun 2014
    15,109
    Sometimes it's just better to take one in the shorts and replace the whole thing. Hope it all works-out for you. Good luck!
