Thread: Bonding - How to do bond your AG pool to be NEC compliant?
    Apr 2016
    Tracadie, New Brunswick, Canada
    35
    I am installing my 27' AG pool in the next couple week now that my deck is done and I was looking at the NEC for pool bonding. Your supposed to bond all metal parts together using a minimum #8 wire and that includes the metal outer shell and each vertical support brace if you are completely NEC compliant. I cannot see how anyone can bond the pool itself without compromising the protective finish of the metal. I wasn't going to do this but I have been googling and in fact many pool installers do this.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,813
    Re: Bonding - How to do bond your AG pool to be NEC compliant?
    All this is min #8 bare copper wire in direct contact with the earth no conduit. Use Split bolt connectors when joining two ends of wire together.
    I am assuming you don't have any paver stones or concrete around your pool.
    One continuous loop around the pool buried 6" down. At least 4 connections to the frame of the pool at equidistant points (for example bolted to the support legs)
    Here is a list of things that need to be connected (I may be missing something)
    light fixtures
    pump
    heater
    metal pool ladder
    metal conduit
    The pool water itself via a dedicated water bonding device
    salt water generator
    any permanent metal fixtures greater than 4 square inches within 5 feet of the pool wall (ie downspouts and gutters)
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
