Thread: Premixing and storing dissolved chlorine granules
    May 2016
    Sandbach
    2
    Question Premixing and storing dissolved chlorine granules
    Hey all!
    Just got a spa, and loving it so far. I was thinking about daily maintenance... our manufactures guidelines says to add 13.5g chlorine granules (mixed with warm water) every day. Would it be safe to pre mix and store 7 500ml bottles of mixed chlorine? Then treatment would be as simple as empty a bottle into the tub daily.
    Additionally, can anyone recommend a reasonably priced chlorine tester solution... if such a thing exists?
    Cheers
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Premixing and storing dissolved chlorine granules
    Welcome to TFP
    You can use smaller bottles of bleach if you want to or just use a quart measuring cup and the Tf100 is worth every penny and will work very good for you
    Here is a great way to set up your spa to be safe for everyday use
    How do I use Chlorine in my Spa (or pool)?)
    Spas and Hot Tubs
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    I have a jug of bleach next to my tub and a 1/4 cup measuring to add. Here is how I have maintained my tub for years, works great! How do I use Chlorine in my Spa (or pool)?. +1 ordering a TF100 from TFTestkits.net! Great kit, I've been using it for years.
