Thread: Finishing off plumbing repair
    Jun 2012
    Oakton,Va
    39
    All, I fixed a leak in a skimmer line and I had to chip away gunite from the top of the piping - in other words they covered the top of pipes in gunite. Should I pour cement over the pipes before I fill the hole in a cover with concrete?
    35000 gallon inground, 2hp Whisperflo, Pentair FNS Plus, Polaris 380
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Finishing off plumbing repair
    Post a pic. Probably not, most likely the thing to cover it with is sand. But, a pic will allow a better understanding.
