Thread: Tigershark impeller getting stuck. Needs kick start or else won't start...what now?
    May 2016
    Montreal
    5
    Hi,
    I just bought a used tigershark. After some troubleshooting today, I noticed the impeller would not start, but once I gave it a kick start with my finger it would start up and remain on. This happens every time i power off and on. Tried some wd-40 but since the motor box is sealed for water, d40 won't get in there. Any ideas besides changing the entire motor box which costs a fortune!!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Tigershark impeller getting stuck. Needs kick start or else won't start...what no
    I would guess that the impeller is being obstructed by debris such as string or hair being wrapped around the impeller shaft. Can you remove the top restrictor plate so that you can see the impeller easier and perhaps remove any obstructions?
    Isolated Spa - 345 Gallons
    Mar 2013
    CT
    349
    I'd remove the impeller and see what is going on. The portion of the plastic impeller that goes on the metal shaft may be worn and not being held tightly against the shaft.
    http://www.inyopools.com/HowToPage/h..._impeller.aspx
    As long as you're going to remove it to check for an obstruction - I'd put a new impeller on.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    May 2016
    Montreal
    5
    I did that already. impeller looks new. removed it and nothing around the shaft either If the motor didn't work at all, I'd say motor is dead, but it works, just needs that kick start
    May 2016
    Montreal
    5
    A lot of viewers but not many comments! Please dont be shy!!
