Thread: Outdoor kitchen wood frame?
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Hi folks, how ok is it to do the wood frame for the outdoor kitchen and how big of an issue it is with wood expansion/contraction due to temp changes? Will the durarock lock it down pretty good and prevent it from moving?
    Thanks.
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Re: Outdoor kitchen wood frame?
    I've a lot of builds with wood frames that seem to hold up over time. My only concern would be around the grill, where you should have some type of barrier (durock) to keep the heat away from the wood. Otherwise, properly waterproofed durock covered wood frame should be good to go.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Apr 2013
    Sacramento, CA
    2,769
    There are two major reasons not to do a wood frame. The first is that you cannot put a grill directly into a wood frame. Grill makers have various different specs on how to install their respective grills. For example Lynx requires an insulated metal jacket. Blaze requires a 14 inch clearance from any combustible material. Other manufacturers have similar requirements.
    The second is mildew and rot. Even well ventilated wood rots.metal and concrete. Will last years longer
