Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Project Swamp
    lovestoswim's Avatar
    May 2015
    Milford, Ohio
    102
    Project Swamp
    Helping a friend. They are flipping a house and with it came the pool! Pool store told him not to add chemicals until all gunk is out, he was having trouble making progress so I told him about TFP.
    First test:
    FC-3.0
    Ph-6.8
    The pool store sold him this shock. He dumped in 10 gallons.
    2nd test after dumping in shock:
    FC-7.5
    Ph off the charts maybe 10 based on color. It was dark magenta.
    Stumped with why ph went so high. Thinking maybe pool store shock is causing it?
    Here are his pump settings -
    I wasn't sure what setting he should be on? While vacuuming he has to backwash every two hours!
    Happy slamming. Hope to see progress soon!
    24,000 gallon, 21x43 Oval Wilbur AGP installed June 2015. 10'X24' deck. 2hp Aqua Pro Cartridge Filter. Using TFP method.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Project Swamp
    PH will be bogus. At free CL levels above 10
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    Quote Originally Posted by AimeeH View Post
    I thought it was odd that two hours before he dumped in all of that shock ph was 6.8 so I had gone over to add some borax, but second check had ph off the charts. So it's just from the high chlorine levels? My PH stayed within normal range when I slammed our own pool so just trying to make understand Thank You!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Project Swamp
    The PH test is invalid when FC is above 10 ppm. Whatever it says is meaningless. PH should have been raised to 7.2 before starting the SLAM, Pool School - SLAM - Shock Level And Maintain. PH below 7.0 can damage equipment and pools. Especially since 6.8 is often the lowest reading in a PH test and in reality it could be much lower than that. I would let FC drop to 9 or 10, adjust PH and resume the SLAM.
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    I learned about needing to raise the ph after we had already started dumping in bleach. 😞 however even after dumping in 10 jugs of shock, FC was only 7.5 when per second check.
    DFW, TX
    24,497
    Re: Project Swamp
    You are probably fighting off some ammonia in the pool. Keep adding FC until it holds. Every 10, 15 minutes if you can.
    Aug 2014
    Northern IL
    4,615
    Re: Project Swamp
    Remember to recheck the pH when the FC is low.
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    OK - thank you!
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    Just checked levels..... FC was well over 10. So I am thinking when I checked last night he must have just added it. No change in water color. Psi on pump had dropped from 25 to 20. I am wondering if there is a clog somewhere. The water coming out of the jets isn't very strong.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Project Swamp
    Make sure your skimmer isn't full of stuff or your weir isn't stuck. Also check your pump basket, if you have one.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    DFW, TX
    24,497
    Re: Project Swamp
    Algae clogs filters quickly. Clean the filter when the pressure rises 25% over clean pressure.
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    Thank you! I will check that when I go back this afternoon. There are not any weirs on either skimmer. I'll check for pump basket.
    I was also wondering if he should use the other settings on his pump or just backwash and filter? There is a waste option, and recirculated, and rinse.
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    Quote Originally Posted by pooldv View Post
    He has been backwashing every 2 hours while vacuuming. I wasn't sure what it meant when psi drops. Could that also indicate a need to backwash as well or possibly a different problem, like a clog somewhere?
    Don't know what I'd do with this site! - Thank You all
    DFW, TX
    24,497
    Re: Project Swamp
    Waste is if you want hook up a vacuum and vac to waste. A pressure drop could be a bad gauge or debris blocking flow to the gauge. Don't use recirculate if they have an SWG. It will just send a lot of junk through the plumbing.
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    Thanks pooldv! I think he was just vacuuming on regular filter setting. Is that bad?
    DFW, TX
    24,497
    Re: Project Swamp
    No, it is fine, it just send the junk to the filter to backwash out later. Backwash the filter when the pressure rises 25% above clean pressure.
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    Day 1 of SLAM complete. I am already seeing a difference. We also pulled out some gunk in the pump and return water pressure is much better!
    Here's today's photo:
    Day 1 of slam complete by nichole babinec, on Flickr
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    Even better a side by side - really couldn't tell just looking at it but the pictures really do help you see the progress
    Took picture on the left yesterday and 24 hours later the picture on the right. Clear steps and less murky for sure!
    2016-05-31_09-03-51 by nichole babinec, on Flickr
    Aug 2014
    Northern IL
    4,615
    Re: Project Swamp
    Like the side-by-side! Good job!
  20. Back To Top    #20
    May 2015
    Milford, Ohio
    102
    Re: Project Swamp
    Quote Originally Posted by MarianParoo View Post
    Thank You!!
