Thread: Halfway thru my draining
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Sure takes a long time to drain..Been about 4-5hrs now and only down 6"..Helped when I had backwash and rinse, for most drained out that way, but garden hose a slowwwww go..Sure hope this helps...
    24x16 doughboy Summerville..22" Waterway "sand" 1.5 HP 2sp motor..Misty Falls liner, and wedding cake stairs..
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Halfway thru my draining
    they are kind of slow it will get there and its worth it..
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Just scares me about the liner...Its not even a year old, but have heard horror stories about draining above ground pools
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    If you have a pool vacuum, that hose will flow 4 to 9 times as much as a garden hose. And the weighted head will keep it on the bottom. Too bad I didn't mention that earlier, huh?
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    lol....now you tell me...ill prop have to stop it soon anyways, for its getting late out here and I don't want to go to bed when its still draining...ill do that when I pick it back up tomorrow..wish I would have started this sooner, for I had a 4 day weekend...urgg
