Thread: Help with balancing
    May 2016
    Manning SC
    2
    Help with balancing
    Just getting started please help. Have AG 4000 gallon pool
    test results using tf-100
    ph 7.5
    fc 35.0
    CC 1.5
    TC 36.5
    ch 125
    cya 125
    Water is green
    Apr 2016
    Sumter, SC
    28
    Re: Help with balancing
    Cya is 80
    Jun 2014
    15,189
    Hello and welcome to TFP! At this moment, the most critical number that catches our eye is your CYA. Did you derive 125 by testing via the dilution method? If not, it could be higher. In any case, a partial drain will be required to lower that CYA before you try anything else. That would be your first priority. Try to get that CYA back down between 30-50 then you'll be better prepared to perform a "SLAM" (link below). Let us know if you have any more questions. Nice to have you with us.
    Apr 2016
    Sumter, SC
    28
    Texas splash...I helped and I entered the number wrong her cya was 80...still partial drain??
    Jun 2014
    15,189
    Oh, okay. I was confused by that at first. They can SLAM at 80, but that's a high SLAM FC level (more bleach). Not sure about the exact size of the pool, but it may help the whole process to do a partial drain - even a 1/4 - 1/2 drain, especially if it's a non-SWG pool. But if the owner is willing to maintain the FC of 31, to include the # of R-0871 drops that go with it, it's an option. I just like for folks to know their options. We'll help either way.
