Thread: Questions about Pool Math
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    If I put in a now FC value and a target FC value it gives me the answer but when I come back it reverts to the same thing I had before and does not remain the same. The now and target values do not remain the same. For me, they always go back to 4 ppm.
    I have some 1 lb bags of Cal Hypo that say Calcium Hypochlorite 52% but there is not a selection for that. The nearest selection is 53%.
    Ned
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Questions about Pool Math
    try opening a new tab and then leaving it there, should stay the same
    53% will be really really close
