Thread: New Member.
    May 2016
    Peabody Ma
    1
    New Member.
    Greeting everyone.
    My wife and I live in Ma on the North Shore. We bought a new house with a pool in the back yard. yes on purpose. We searched for a larger home with a in ground pool on purpose.
    It had some issues after a few years with a leak underground and some concrete settlement issues with the patio.Its a gunite pool.
    Well to shorten it up we had the pool and all the decks refinished this early April. IMG_1302.jpgIMG_1700.jpg
    we had the decks done in exposed aggragrate and the pool refinished in pebbletech. new skimmers all new plumbing except for the returns which were in excellent shape. Now that things are working correctly. I have some questions. I wired the pool for a heat pump in the near future and had the equipment pad sized to accommodate the new heater as well.
    It's just a question of which pump? The pool is 6 feet at the deep end and 3 feet at the shallow end. It holds 18000 gallons of water.
    Thanks for any help received in advance. It just dawned on me to look for a forum for pools after cruising my usual motorcycle forums.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Member.
    Welcome to TFP
    Bigger is better, get the biggest one you can afford..
    gas would be 400,000 BTU, use if you only want to heat occasionally like weekends
    heat pump: these are used when you want to set the temp at 85 and keep it there
    solar heat: more expensive up front but free heat once it in, it will use your pump when activated
    all 3 will need a pool solar cover to keep your paid for heat in
    I hope this helps
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Re: New Member.
    Welcome to TFP!
    I think I would go with this pump for your pool. Here are a couple of places to buy it.
    Pentair SuperFlo VS Pump 342001 | Pentair 342001 sunplay.com
    Pentair SuperFlo VS 1-1/2 HP Variable Speed Pump (220V ) - 342000 - INYOPools.com
    Becoming a TFP supporter will get you a discount with INYO and of course a great badge for over there <---.
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Casey's Avatar
    SW PA
    10,494
    Re: New Member.
    Welcome!
    Marlana's Avatar
    Aug 2016
    Massachusetts
    1
    Re: New Member.
    Looks great! we are also in Peabody who did the deck?
    Brenngun's Avatar
    Oct 2016
    Toronto, Ontario
    17
    Re: New Member.
    Love the change.
    19K gal IG vinyl, AuqaRite Digital TCell15 SWG, 3/4HP Tristar Pump, Hayward 4030 Canister Filter. Gas Heater, Navigator Cleaner.
    Simple solutions resolve complex problems more often than complex solutions solve simple problems.
    Despite the high cost of living, it's still very popular.
