Thread: Granular Clorox CYA
    Jul 2014
    Evansville, IN
    72
    Granular Clorox CYA
    I put 20 ounces in a sock, sat it in the skimmer, then proceeded to squeeze the sock for 5-10 minutes until the cya was completely dissolved. I then noticed my pumps psi went up 2 PSI. Is this okay? Since it was dissolved (milky) I don't know why my pressure went up. Thoughts?
    16 x 32 Sport Pool; Hayward Series Sand Filter S244T
    15,000 Gallons, In Ground with New Vinyl Liner
    Pool approx. Five Years Old. Live in KY
    JoyfulNoise's Avatar
    May 2015
    13,176
    Re: Granular Clorox CYA
    The CYA is now likely stuck in your filter. Wait and see if the pressure goes down. Backwashing will only flush all the CYA you added down the deain
    Matt
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    I always hang the sock in front of the return jet,, hanging in a sock off the handle of a shovel. Otherwise it clogs the filter if you put it in the skimmer
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
