Thread: First Swim accomplished thanks to TFP!!
    Apr 2015
    Boston MA
    93
    Hi everyone,
    That was fun!!
    I can't believe that I was able to perform chemistry tests with all your help and have my friends and family swim safely this Memorial weekend.
    A huge thank you to everyone that helped and reassured me this past month.
    The pool looks and feels fabulous.
    .......as per usual, here are this evenings results after a busy weekend swimming.
    Weather-a lot of rain this morning....
    FC-3.0
    CC-0.5
    TC-3.5
    CH-50
    TA-140
    CYA-70
    PH-8.2
    CL/BR-5-10
    Salt-2800ppm
    I do think the rain this morning has skewed these results a little. Having put these into Poolmath it has asked that I add 68lbs bags of salt... to be honest I might wait until tomorrow and perform another test, or should I do as the calculator suggests.
    Its my first real test and swim, albeit after a significant day of rain.
    Thanks so much again everyone. I hope you all had a fun weekend.
    15x30 Oval 13,500 Gal, IG Vinyl built Fall 2015,
    TF-100 test kit
    Pentair Sand Dollar 40 Pump & Filter System 1HP Dynamo
    Pentair Intellichlor SWG, Dolphin Nautilus
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: First Swim accomplished thanks to TFP!!
    Congrats From those tests I would bring your FC up to and target 5 and add some MA to drop your PH, with your TA at 140 your PH will rise a little fast but as you take PH down you TA will also lower
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    What fun! SO nice to see you are really getting it! And to get to enjoy the fruits of you labor with friends and family! SWEET!
    Kim
    Apr 2015
    Boston MA
    93
    Quote Originally Posted by cowboycasey View Post
    Appreciate the information Cowboy. Time to get this pool back in order!!
    Thank you
    12,000 Gal,IG Vinyl,Pentair 1HP Dynamo,Pentair SD40,Pentair Intellichlor SWG,Dolphin Nautilus, TF-100
    TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    Yep, keep some bleach around to help out the SWG when needed. It is a lot easier to add some bleach from time to time than to adjust run time and percentage up and down all the time.
    Congrats on a great
