Thread: Sta-Rite PE5E - 182L Overhaul Kit
    May 2016
    Modesto
    1
    Hello! I need some help. We have a Sta-Rite PE5E-182L pump. Of course, as a heat wave is coming here this week, the impeller appears to have stopped working. I am clueless as to what overhaul kit I need, there are so many of them, and they do not specify which one they work for. Does anyone have information on how to find out which one you need? I can't seem to find this information online.
    Thank you in advance!
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Sta-Rite PE5E - 182L Overhaul Kit
    I am not sure what you are referring to. Is the motor turning the impeller, is the motor just humming, is the impeller broken? What are the exact symptoms?
    Mark
