Thread: Brushing
    May 2016
    Brandon, MS
    34
    Brushing
    How often do I need to brush? Daily, weekly?
    Also, do I need to brush the bottom of the pool if I am running an Polaris 360?
    Greg - Mississippi
    18' x 36'* 23,000 gallons * Vinyl * Manual Chlorination * Pentair Sand Filter * Pentair Variable Speed Pump * Polaris 360 * TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Brushing
    Once a week ought to be enough unless you live next to a field and the farmer is out plowing.
    Even when the pool looks perfect, it's amazing how much fine stuff is sticking to the walls. It's the aquatic equivalent of dusting the blinds in your house!
    If the polaris gets the floor clean, I wouldn't bother brushing it. Although brushing the floor is loads easier than the walls.
    May 2016
    Brandon, MS
    34
    Re: Brushing
    That actually answers another question I had too...I always find at least minute amounts of dust on the floor when i brush. I was hoping this was normal.
    Thanks Richard!
    Greg - Mississippi
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Re: Brushing
    That's funny Richard because I actually find the walls easier to brush, but I'm using a wall whale now. Lol
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
