Thread: looking at buying above ground pool
    May 2016
    Missouri
    13
    I am looking at purchasing my first above ground pool have looked at a couple of places and feel overwhelmed with all of this information and choices i am currently looking at a 18x40x52 oval pool from thepoolfactory it is the saltwater 5000. Is this a good pool? I am not wanting to do a saltwater system, do to it being close to a metal fence. what kind of pump and filtration system would be best this pool is 19,000 gal? What type of chlorination system should i buy? Is there anything else i should buy right away?
    Kc mo, mom of 3 and a farmers wife
    Looking at a 18x40x52 Above ground pool
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: looking at buying above ground pool
    Welcome to TFP
    spend some time an check out some of the builds, grab a test kit
    Just so you know, all chlorine pools are salt water pools, salt is used to stabilize the chlorine
    I would and almost always recommend a SWG but they are not for everyone below is what I would get from there
    Apr 2015
    Waterford, MI
    133
    Saltwater pool with SWG is the only way to go imo, its just so easy!
    Michigan - 24'x54" AG, approx 15,000g, 2 center drains, Cartridge filter, Aqua Pro 2hp, 2 speed pump 3.5a@1725w / 10.5a@3450w, AquaCal TropiCal T90 heat pump, Hayward Salt & Swim SWG, Poolskim, Aquabot Rover Jr.
    May 2016
    Missouri
    13
    What are the advantages of saltwater system vs a chlorine system?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    With a saltwater chlorine generator (swg) you make your own chlorine and it is released into the pool depending on how your have the swg set up. SWGs can be adjusted to increase or decrease the % of chlorine created, depending on what is needed. If you are going to chlorinate manually, then you will need to have several gallons of plain, unscented bleach on hand at all times. You use your test results and PoolMath to determine the correct chlorine level and dose the pool appropriately. You should check the chlorine levels daily.
    Love TFP? Become a
    TFP Supporter!
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by Trick View Post
    THIS!!! 😀
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
